Blue LED light won't go away
Feb 1, 2013
9
Alright so a couple of weeks ago my S4 got a little wet in the rain, since then this blue LED light is stuck in my phone and just won't go away even if the phone is powered off. Everything else is working just fine. Is there a way to get rid of it?
Thanks!
You are assuming it has something to do with the rain, but it could be something entirely unrelated.
Do you use a notification manager like Light Manager or Light Flow? If yes, that could be the actual cause of your stuck LED.
Nope. No manager whatsoever. What could be the reason? It only goes away when I pull out my battery and as soon I put it back in the stupid light turns back on. The reason I'm assuming it has something to do with rain is because it turned on direct after contact with rain. Never have I ever seen it before. So annoying!
Best guess is that there is a droplet of moisture in there somewhere. It will more than likely dry out eventually and then the led will go off.
That's all I've got. :)
