Bluetooth problem
jconn
5
I got my Droid on Sat. and love it so for. It's my first smartphone so I'm sure I haven't scratched the surface of what it can do. My problem is I can't seem to get my Jawbone to sync with it. I've followed the instructions as far as I can tell. Thanks for any help.
I didn't have a problem with my jawbone. Are you putting your jawbone in pairing mode then your droid should see it.
1) make3 sure the jawbone is in "visible" mode, so the phone can find it
2) go into bluetooth settings, and add a device
3) enter the passcode, usually either 1111, 0000 or 1234. (I don't use a jawbone, so I dont know which it is)
Those steps should do it up for you..good luck.
alshrmani 77
