Bluetooth Sound Quality
mylesimp46
After using my new Nexus 7 for about a week I've noticed when streaming Bluetooth the sound quality is horrible....my RAZR Maxx HD sounds so much better with much less distortion... Has anyone else experienced this issue or do you think it wouId be best if I exhanged my tablet? Thanks!
Sent from my Nexus 7 using AC Forums mobile app
Welcome to the forums!!
I don't have either, but here may be a couple possibilities.
1. The Bluetooth radio is bad in your device.
2. The Bluetooth radio quality isn't as good as the one Moto used.
Haven't noticed any sound quality issues streaming from my Nexus 7-13 to my Alpine stereo in my car. *shrug*
I stream bluetooth to a Panasonic sound bar at home. I've noticed that the quality is much better than streaming bluetooth from my HTC Evo4G LTE. There is not nearly as much "noise" streaming from my N7. That said, bluetooth streaming in general, leaves a lot to be desired.
I compared the sound of a full .wav file on a set of BT Headphones and a set of wired Headphones. They were of similar type of open-cell foam pads on the outside of the ear.
I could definitely hear a difference, the BT set was low dynamic range. The wired set sounded much fuller. It might not have been the signal transmission method that caused the difference, but it's possible. Isn't BT audio compressed like .mp3 files? I can't stand .mp3 files due to this.
I haven't done a real comparison, but I do think it isn't as good as the BT on my iPhone 5.
Sent from my Nexus 7 using Tapatalk 4
Yeah after listening to it more its definitely not right...I guess I'll be calling Asus tomorrow!
My Nexus 7 is the only Android device I have that can stream Tidal streaming Master recordings. In my system it sounds like SACD. I hesitate to say your device is bad only that I can't explain the inexplicable audiophile quality of mine.
I googled to see blue tooth specs and the Nexus has 4.0 the Tab S2 has 41 so I just consider myself lucky.
rcmphoto
