Bluetooth with JBL Flip..
Holding the Power button down till it beeped twice did the trick and reset my JBL Flip. It then appeared while my tablet had the Bluetooth scanning enabled and I was able to pair it. Thanks for the help!
Hi I had the same prob. Yoh need to reset your JBL Flip
Hold the on/off button down until it double beeps and flashes red and blue
Then turn your bluetooth on on your phone & it will find it :)
Thanks. I was struggling with this problem. Your suggestion solved the problem in seconds. Thanks a lot.
dont know if its relevant but tried holding down the on off button on my flip 3
just turned on and off, but finding the proper scan button on the speaker did
the trick
bad instructions or lack of them from jbl
khatunkhatunc
