(BLURRY IC3) TH3ORYPAX Power Widget Question
prizeferret
140
14
In Blurry IC3, there is a toggle on the powerwidget to turn off the 3G/4G antenna completely (far right icon), as opposed to just not sending data through them when on WiFi. (To eek out a little more power savings)
Does anyone know of a way to automate this toggle to turn off when on WiFi, and then turn back on when off WiFi? I've tried Profiles Setting, but it apparently doesn't have the capability to control antenna function.
It's my understanding that when you are on a wifi network your 3G/4G data is turned off anyway, automatically by the OS. The toggle they have for data would just be needed if you want to turn off data while you aren't on wifi either.
I know it does enough to remove the 4G/3G icon completely from the status bar, which is different from the standard WiFi connection, where it just sits idle.
Can someone walk me through the icons on the power widget? Wifi then bluetooth then...?
Sent from my DROID BIONIC using Tapatalk
I believe they are: Wifi, BT, GPS, Sound, Auto-brightness, screen rotation, mail/social media sync, 3g/4g antenna.
pcjordanellis
