Boot Animations Lists and Links with Instructions - Updated 02/16/11**
Status
Not open for further replies.
i deleted the old shutdown folder and replaced it w the new folder of .png files i extracted from the download zip and nada.... I also tried the lloyd beating the mac sign with the bat (it says flash thru recovery) which i did... the process completed w no problems but wen i shut down n boot up the phone... nothing... I am running superclean 0.4.... i currently have no boot up or shut down animations on my phone now
What kernel are you running? Some do not support boot/shutdown animations.
I cannot tell ya what could be out of whack as long as the new Shutdown folder was named correctly and placed in the System/Media/Video/ folder you should it should be operating.
Roll it back to the ROM backup you made and start over... If you did not make a back up you may have to reflash the sc.4 ROM to get you back to a good starting place.
To replace the Shutdown sound you have to do the following:
1) DL a new sound file
2) convert to .ogg file (I used Winamp+.ogg converter)
3) put on SD card
4) open Root Explorer
5) navigate to /system/media/audio/ui
6) rename "shutdown.ogg" to "shutdown.ogg.old"
7) navigate to the DL'ed .ogg file
8) copy
9) paste into /system/media/audio/ui
10) rename it "shutdown.ogg"
that winamp can be found on the market? im having problem when hooking up the phone to the computer and being read as cd-rom i think the kernel needs to be changed with adrynallyn's test 5. so for now cant mess with computer and transfer files to the phone.
damn that sux... Any kernel suggestions 4 a noob
I one of the best nonvoodoo kernels is stupidfast 1.76 or 12/20.
Adrynalyne has some really good test kernels up that also work. If you check the ROM/Themes and kernels post that will have quite a selection. I have been personally fond of imnuts versions.. they are a bit larger in size but have a great operating record.
hello, first thanks so much OP for this guide
I just rooted today and was looking to get a new bootanimation
i am resorting to method 3 because flashing the decepticon one did not work, but i am having trouble locating the original bootanimation.zip that needs to be renamed. i am in the correct systems/media folder... the closest things i see are bootsamsung and bootsamsungloop.
any suggestions? i didn't want to replace a file that wasn't mentioned on teh guide...
I also dont understand how you can get su access to an app as mentioned in method 3. is there a special way of opening it? (i am using astro)
many thanks. excuse this noobness :)
Throw the bootanimation.zip you made into your data/local folder.
Your phone will look there first for the boot animation and if it finds one it should ignore any other one.
Reactions: ajchoi16
Any word on Boot Animations working with SuperClean.7 or Stock Froyo leak?
I know that Adrynalyne cleaned out the stock boot and shutdown. There needs to be a custom kernel built to accommodate the boots and shutdowns on the OP.. I have been scouring the forums and ... no new kernels yet..
birdman had one he was testing a few days ago but all I know is it would boot... beyond that I have not come across anything...
sonofskywalker3 has pulled down his portion of ROM Manager to update it (Blackhole 4.0) - that may be the first location to look for a boot/shutdown.
I saw on Twitter were birdman is also doing some testing but I am unsure if it is a kernel or not.. looking for volunteers.. umm yeah - no thanks.
I will be on the alert.. as soon as I see anything break I will have it up..
Yeah, I wish he had kept the boot animation. There doesn't seem to be any point to having a blank boot screen, but I guess he's keeping his options open for when those kernels become available.
hmmm i cant seem to find data/local folder. phone says data folder is empty
so instead i tried to move bootanimation.zip into just the data folder but could not. apparently i cant move file from SD card into phone with astro? do i need to get another file managing program to do such actions?
I would guess that you are not using a file manager application that is able to read/write using root rights... Astro does not appear to have that capablity.
You will need an app like (Super Manager or Root Explorer) - First is free the second is a few bucks... both are available in the market.
If you are currently running DL30 or superclean .7/.6 - this will not work until a custom kernel is built and released.
Unable to get the carbon fiber animation to start. Placed in all the appropriate places, just get a blank screen but I do get the new startup.wav file I used.
First question: What ROM/Kernel combo do you have in place?
Edit: I noted you are posting that you are using DL30 - Currently there will be no functional boot animations for that ROM or kernel until a custom kernel is built and rolled out.. Sorry.
Reactions: vluc
No problem, that was the question, although I was able to change the shutdown screen.
Status
leodas0705
