Bootloop problems, clearing cache and factory reset doesn?t work! need help
rabinah
My galaxy s3 got low on power and turned itself off and when i got home to charge it, it wouldn?t charge or start at all.
I then went into repair mode and it started charging, i then cleared cache and did a factory reset and i rebooted, then it went into a bootloop and i?ve tried to do this many times but it does not work....
I?ve tried googling it but it just says "clear cache and factory reset the device" and i can?t turn it in to my provider either because i broke my screen so they refuse to even look at it.
what should i try to do so my phone works?
Best regards Robin
(sweden)
You can put it into Download mode and use the Kies software to reload the correct ROM for your model/carrier.
Kies will prompt you for the model number and IMEI - that information can be found under the battery.
Sent from my SCH-I535 using Tapatalk 4 Beta
DonUAE
