BreakingKayfabe
Banned
- May 16, 2010
- 146
- 17
- 18
would there be anyway to get a Full SBF? i have RSDlite now, but is just using the system SBF ok to use going from this rom? GJ 2.5 (idk if that has anything to do with it) or will just the .340 SBF from the droid-life site do the job? i just dont want to brick the phone lol
I have a full .320 SBF if you need it. All you have to do is install the patches
from the link that wildman gave you after you're done with the SBF. When
I did it, all I did was the following:
-SBF with RSD lite 4.8 (Full .320 SBF)
-Root the phone with z4 (It was painless)
-Flashed the system updater in bootstrap then rebooted
-Flashed the bootloader in bootstrap then rebooted
-flashed the kernel in boostrap then rebooted
-flashed the baseband in bootstrap then rebooted
Then flash whatever compatible ROM you want. I've flashed Rubix 1.9.5 and
GummyJar 2.5 without a problem.
Note: Once you .320 SBF and the phone is rebooted, your radio signal might
be pretty weak. Make sure you get to an area where you can get some signal
so you can *228 the phone. Once you update the system as I explained your
normal signal should reside with 20 minutes or so. That's part of the baseband
update's job.
