[BRICK WARNING]Dont clear phone via Menu>Privacy after custom rec
Try it, and let go of the buttons as soon as the splash vanishes. Thought it was normal for all devices, but if I don't let go of the buttons, I don't go in to recovery :P I've never tried holding it for a long period of time, so no idea if that could cause an issue :P
Ok That didn't If I Can't Get Into Recovery Or Emergency Mode Then I guess Its Bricked but What Are The Buttons Needed To Get Into Emergency Mode
Thunderom booting to recovery
Hi all-
I have two phones running thunderom 1.5. Both have been running for about two months with no problems.
Today one of the phones started booting into recovery. I tried just restarting and that did not work. Neither did pulling the battery and restarting.
Any ideas on what I should try next? I was thinking of updating of 1.6.2 and seeing if that helped.
Thanks,
Mike
I would try to figure out why it was happening or do a full wipe before installing 1.6.2 just to make sure some app is going crazy nuts.
is it possible you went into Menu > Setttings > Privacy > Factory data reset?
Also as Beezy said, 1.5 is kind of outdated. Might be worth the effort to try the following ...
1)Put 1.6.2 on your SD card and wipe cache and dalvik (not data) and flash the ROM. See if it boots. if no ....
2)Wipe cache, dalvik AND data, flash the ROM
Reactions: mikegerard
Just talked to my son and it sounds like he tried to do a factory data reset....arggg.
Going to try to unroot and see if that takes care of it.
Mike did your PC or laptop see the device how did you get to push the files on the first instructions my phone is in the spot that yours was and all my girlfriend did was the same thing as your son did and I'm stumped I can't get the files on the phone its the second command and it just shoots a error saying device not found?
Sent from my PC36100 using Tapatalk
I was able to use adb on my pc to push the files to the phone.
The phone was on the recovery screen the whole time.
Mike
Well… My phone is stuck on the load screen. If I take a brick to Sprint do they freak out or what?
I really think it’s a soft brick but I just have not the talent to unbrick yet.
I just realized that prolly sounds really lame to most of you guys... :P
Ok… so as you all probably know if you root your phone then Sprint will NOT work on it and it voids your warranty even if it is insured. So the guy told me to go crack the screen and send it in to be replaced.
Xionia CWMA Recovery now fully supports this option, no brick, and it works. Be warned though it does unprovision your phone (intended to do so) so you will have to wait for Hands-Free activation and all that crap.
I wish I know how you all are able to do an adb shell connection..
I have yet to get my phone connected as of yet..
I have even disabled and enabled the 4 driver's that are used with the phone
(GPS,MODEM,COMPOSITE & the SERIAL driver)..
Im sure the serial driver is what is needed (as I dident pay attention to witch driver was used when doing the ROOT earlier this month..
I know all files are up to date as I was in adb shell 2 days ago and had no issue's..
Must be an issue with the "Debuging" driver on the phone side is not activated..
Any thoughts?..
Do you have USB debugging enabled? Sometimes in various resets and restores it gets disabled and you don't realize it.
The particular interface you care about is listed under "ADB Interface" for devmgmt.msc
It'll say Android Sooner Single ADB Interface.
If you don't see that when you connect your phone, then something is not configured correctly, likely either the drivers or the USB debugging setting.
The phone must have debugging turned off..
I have flashed and re-flashed stock Nand's as well as some backups I have made where I know USB Debuging was on..
Still a no go...
When ever I plug in my phone to the PC while in recovery the USB is stated to be using "LGE Android Platform USB Modem #2"..
Also SuperOneClick just hangs at "waiting for device" promp..
I just do not get it..
Plus if its any help Im running on Windows 7 (x86) with a LG Optimus V
Under
menu->settings->applications->development->USB debugging
just double-check it is checked.
When you plug the phone in, does it say usb debugging in the status bar?
It is possible somehow your driver setup got messed up on the PC side.
Under
Thats the issue right there..
Im in a constant recovery loop and Im not able to access the main OS to change such settings..
I have tryed all my Nand flashes and even used a stock Nand flash thats found here for my Opti V:STOCK OPTI V Nand BACKUP
& within "Mounts" on the recovery menu the only thing thats mounted seems to be the "/cache"...
Im rather new to this so bear with me if you could please..
In short though thats my main issue as the phone doesn't seem to have the debugging mode enabled..
Thought that setting would be set within the Nand backup witch I know the first backup I had done had the USB debugging mode on..
Any further help would be greatly appreciated..
dumpsterrentals89
