Bricked LG G2, Stuck at TWRP, No Download mode!
benim
lg g2 d800 model​
hatalı bir eklenti yüzünde açılmıyor recovery mode geri gelıyor pcı usb olark gürüyor kaç tane yazılı m yükledim aynı sorun recovery mode geri geliyor bunun çare sı nedır yardımcı olursanız sevınırım teşkürler
[Google Translate of above post from Turkish:]
my lg g2 d800 model does not open on the wrong side of the plug-in recovery mode comes back pci usb is giggling how many written m installs the same problem recovery mode comes back,
before trying anything else just type in these commands
What worked for me was from the TWRP terminal command was to type
dd if=/dev/zero of=/dev/block/platform/msm_sdcc.1/by-name/fota
then hit enter
type
dd if=/dev/zero of=/dev/block/platform/msm_sdcc.1/by-name/misc
then hit enter and reboot.
got help from the IRC xda-devs for the second step to complete the fix.
What if it says "Not enough space left" ... ? What do I do then?
dont know how to say thank you man. appreciated. It worked well and you saved my hours.. Thanks a lot
Nazeer zaheen
