Bricked My EVO, but there is away to un-Brick
Status
Not open for further replies.
@EvoFanatic
This method should fix your issue. I found that if you turn off the phone it will charge. I was down to like 5% battery life when I finished, because I was still having to work and use the phone in between steps. It really sucked. If you are having issues getting your system to load drivers. Unplug the usb cable from phone. Load into Bootloader. go into fastboot, then plug in your phone. This worked on my Windows 7 with no problems. I at home for a bit if you need any help.
Okay so I`ve lost USB and SD card...I`ve tried fastboot and CMD command but get that file/batch is not available? I just want to go back to the stock evo...without root. What is the easiest means? I`ve spent hours trying different things, but cannot. Any help please!
When you are in fast boot, does windows detect your phone? If so, from you adb (command prompt) can you type in adb devices and if you see your device then you are good. From there, let me know what is going on so we can get your phone working. If the battery is getting too low, turn it off then plug in the power, it will charge this way. I am going to be up late tonight getting ready to go float the river this weekend so will be unavailable once I goto bed around midnight tonight, until Sunday evening late.
I tried. All that and nothing happen i manage to use the RUU and update. My evo to the 1.47 with the same problem and take it to the sprint store they do a master reset the tech try for about a hour. They. Give me a new one. The evo was functional no sdcard and have to turn off to charge.
In fastboot, my windows makes a noise that is associatied with plugging in a usb. When I look at the devices I see in the unspecified section, Android 1.0. CMD wont show any list devices under adb devices.
okay, so windows is seeing it. that is good, but wonder why adb doesn't see your phone. I will look at some stuff, and try and get some others in here to help, but that isn't making any sense.
@mrdpr, but you need USB support, and when the sd card goes like this and it doesn't charge, it usually means that the USB doesn't allow data on it, unless you are in recovery mode.
Saepak i put it in fastboot with the RUU open and miraculous i can unroot to 1.365.1 and make the update to 1.47 take it to the store and they order a new one.
@Saepak, Disregard all previous...problem solved....Got a new Evo....for FREE. Thanks for the attention and support!
Good to hear SKOVY, how did you get an New Evo? Hope it is working out for you. I just got back in from being out of town for the weekend.
Correct t0ast3d, but when that is how it is posted over on other forums when you start the process then that is how you post it. I would of changed the title but have no clue how to. There is alot of better terminology to be used now that I know what the heck is going on and that there is a real fix for it. If you know how to change the title let me know. I asked back at the start of this tread but no response.
Click edit and then press go advanced. There you can change the title
That doesn't change the Main title that is on the Forums page. Just the Title of the individual post, I new how to do that, but it isn't very important.
I have my evo bricked. and When I try to make the fix. it keeps throwing the same log. Do i m doing it good?
Status
JimBrown333
