Bricked my LG Optimus V beyond repair?
Greetings,
No mistake on your part what-so-ever. My mistake was not putting the needed files
in ADB directory. I think I was so frustrated with all of it, that when I realized
I was getting a new phone the "pressure" was off.
It was at that point I could look at all the instructions, and it suddenly became
very clear. Another of my mistakes was failure to put a "space" before the backslash.
ie: adb push recover.img /sdcard/ the right way
Here is the way I was typing in.
adb push recover.img/sdcard/ I left out the "space" between the g and backslash.
I then followed with: adb reboot-bootloader, followed by
fastboot flash recovery recover.img followed by
fastboot reboot
And that was it. The phone booted into CyanogenMod-7.2.0-RC1.
That's my story. If there is ANYTHING I learned is. Be patient. I found that to be the
most important. And If I could fix my phone with the help of all you great people
then anyone can.
Thank you so much,
Reelburner.
Thank you ReelBurner, that is helpful. Once again, so glad it was fixed, thanks very much!
Sent from my VM670 using Tapatalk 2
I like it. The soft skin fits like a glove with all the soft buttons in the right
place. Flaps that cover the charging port and headset plug.
Only drawback(if it's really one) is no access to SD card without removing the entire case.
Other than that, I highly recommend it. Got mine off Amazon for $27.
Not to go off topic, but I have one too and the headphone flap fell off within a week. Not sure if my situation is rare or if this is a reoccurring issue. Just a heads up.
Thanks for the heads-up. I've had mine for about 2 months now and
flap is ok, however, I haven't used it much either.
i have a huge problem i rooted my optimus s and had it going then didnt do a backup and went to install cyanogen mod 7 and used clockworkmod recovery to install but it wont go anywhere i get to the recovery screen where it says reboot system, apply update from sd card, wipe data factory reset, wipe cache partition, install zip from sdcard, backup and restore, mounts and storage, advanced and power off but whatever one i hit it just shows the screen with the tophat and arrow around it but doesnt go anywhere
Do you mean optimus v? These are the v forums, there are recoverys that select with camera button and those that select with the home button just try them to see which yours is :)
kevin_bkt
