Brightness changes (gets brighter) when phones battery gets low.
ab0mbs
14
I recently discovered that when my phone tells me that the battery is low and I should connect the charger, the brightness goes up. I checked in the settings and the brightness bar has gone up too. When I plug it in, the brightness goes down again.
I was wondering if this happens with anyone else?
Thanks.
Thanks.
Hi Abombs,
I never really paid attention, but I will look out for it and update you on my findings.
You probably have the brightness set higher for power saver settings. Go to>Menu>Power>Power saver settings... and check and see if the screen brightness setting is higher then what you normally use.
Reactions: ab0mbs and lovy
Wow I didn't know this, I'll take that advice also, thanks Cyber :)
