Browser Problems
giancarlo93
6
Hello
I just updated my galaxy s2 to firmware 2.3.4
Everything works minus the browser and youtube.
I downloaded firefox and it browses like normal.
Whats wrong?
What should I look for?
thanks in advanced.
I guess this is a problem with the network settings of the previous SIM card.
The APN has to be added either through a push message from the operator or manually.
Put back the earlier SIM and wait for the operator to push the settings, or if you know them you can manually update them @ Settings -> Wireless and Network -> Mobile Networks -> Access Point Names
Hope this helps.
Thanks for your help.
That's what I did.
I pull out my cable & wireless sim card, then inserted a movistar sim card and the again the cable & wireless one and now it works perfectly.
I use dolphin HD It has tabs like firefox and seems to be fairly stable. Firefox also has a mobile browser, but I have never tried it
Ashok Dharshan
