Bugs in Froyo
Not sure if this was brought up: I use the built in Music player all the time. In 2.1 I was able to text, email, browse the web, etc while playing music with no problems. Since upgrading to 2.2, whenever I try to do anything like text or email, the music starts skipping. Then if I keep "multi tasking" the music app will actually lock up on the screen and the phone will not respond to any input but the music will continue to play.
I just downloaded Double Twist to see if it does the same thing. I liked the built in music player because it had the play controls on the lock screen so I didn't have to unlock the phone to skip a track or pause the song.
Mine has done this a few times, but not consistently.
To add to this bug report though, the music player COMPLETELY hangs the phone if turned into landscape mode while playing.
Anyone else's phone not vibrating when receiving texts? I tried reboots and battery pulls but can't find a solution.
Ive noticed that too, irking the crap outta me. Anyone else notice it? Any ideas how to fix it?
EDIT.
If you go to Battery Manager and go to custom battery saver you can see Display brightness. The marker for current display brightness shows that it's not all the way to the end. I double checked it to see if the current display is all the way down and it is. I'm thinking that could be a bug right there. Can anyone else confirm this?
Im glad somebody else is experiencing, ive had no luck fixing it so far.
Anybody having trouble setting speed dials? I go in to set a speed dial, my contacts come up, I select one and nothing happens...aside from that, Froyo seems pretty decent.
Has anyone figured out how to fix this? I deleted a speed dial that I had set up from 2.1 and it won't let me put any speed dials back. This is really weird. Thanks!
Anybody?
This is driving me insane!
Thanks, folks!
Screen does not light up after unplugging from charger in 2.2. Very annoying.
Compass will not calibrate. Fixed by powering on/off before calibration.
GPS will not automatically shut off when exiting some programs.
Checking battery stats causes settings to force close.
I am having a bluetooth issues. I used to be able to pair with my samsung headphones but I can't now. Crap!!
my friend has a droid X, and had the vibrate silent problem, did a factory reset and the problem was solved, but is still having an issue with music for SD card saying its not supported? any one else with issues like that?
2bit developer
