Bugs in Jelly Bean
I no longer have lockscreen widgets for spotify. Only the HTC music app
Sent from my EVO using Android Central Forums
Yes speakerphone is just as loud as before jb update. It was never that loud enough in my opinion. All voicemails were and currently sounded low and I always had to increase volume
I don't know of a work around for proximity issue but hope there is our it is fixed/patch update soon.
Nope. Kind of annoying. Never had a widget for Pandora. Maybe its just spotify and the way its coded though, for jb. Also I did notice beats audio actuall seems to do something now.
Its like stupid loud and actually makes me notice shut in the music that Idont normally hear. Especially on headphones and car speakers.
From everyone experiencing proximity issue now, it must be problem from jb update. Hope it gets fixed soon.
I'm having the same Wifi issue with my DLink router...tried every method of connecting and unchecked that advanced wifi option, as well. As for the person that brought up the closed off Haptic feedback, turn off the Power Save features and it will come back on. Its turned off by default.
THIS...once I use the phone function I can't get the sensor to turn off unless I do a restart. I know coding is a difficult process and want to cut HTC some slack...but this is ridiculous.
Agreed Andras. Proximity issue, It was a major problem before the previous update. HTC should have made sure it was fixed for this much anticipated jb update. I'm pissed off that I also have to restart phone for this annoying issue.
I have no proximity sensor issues! When I put it to my ear it shuts off the screen, and when I remove it, it comes back on!
Sent from my EVO using Tapatalk 2
What do you mean by this? After a call when you go back to your home screen and put your hand by the ear piece your screen shuts off and when you take it away it comes back on?
Or do you mean once the screen turns off it won't come back on?
Lucky cat. Hope it stays functional for you. Keep us updated. It's strange the bugs are different from each user.
I've had no problems with the update. Everything seems to be working fine. 109 apps updated just fine.
I'm afraid to download this update. It seems I have a 95% chce of getting a some kind of bug after reading this thread.
Dude, download the FRICK out of it. Yeah it has some glitches but its the kick. For real.
oval_clarity
