Bugs in Jelly Bean
My pictures that I'm sending as MMS are very grainy (when you view the pic after you send it from the thread). Anyone else have this issue?
Not sure if its cuz my phone is refurbishedor what but I didn't really have any issues with ics, nor am I getting any huge ones with jellybean. I think if they release a maintenance update JB coupled with the now low price point would put this in a firm top three for sprint. It made everything seem new and awesome again. The only big problem...and its not that big was with my WiFi. Got that figured out now though.
Sent from my EVO using Android Central Forums
I had big WiFi issues when JB first updated. It would see both of my home networks (2.5 and 5.0 GHz) but no routing even though it said it was connected to the network.
A hard reboot of phone fixed this... also fixed other problems later...so several hard reboots after JB helped.
Also the phone in JB sees both 2.4 and 5.0 GHz WiFi and works on both of them now. Also try just deleting the home networks from phone, search for them again and then connect.
Does your haptic feedback on it work still? I seems to have lost that feature. My haptic feedback works in/on every other aspect of this phone, except for when I use the Swiftkey keyboard.
My Swiftkey talk to text works great.
EVO-LUTION 4G LTE
After I fix my wifi I have been more then happy with the whole jb experience,, this device rocks now, I would now go toe to toe with any device.
EVO-LUTION 4G LTE
My notification screen doesn't seem to be any different than before the update. I have the power save and the clock but when a notification comes in I thought they were supposed to show more detail along with some priority options. Was I wrong I thinking this?
Certain notifications are expandable. Zoom-in-pinch on a notification horizontally and it will expand if it can. Two that I have already used plenty of times today include htc mail app and Google Play music. You can pinch it back together as well.
I want my clear see through calculator widget back. Dam them
EVO-LUTION 4G LTE
That did it, thanks.
Everyone try this: Go to your new voicemail app. Play a message. Hit the speaker phone icon. It's broken for me- when I select the speaker phone, the audio is barely audible, and static-y. My messages play louder through the earpiece, than through the speakerphone. Very annoying, please FIX ASAP. Anyone else having this problem?
Beats audio (on) is insanely loud. Treble & bass tuned is totally off. I seem to have an abnormal high ram usage too.
Voicemail working ok for me. Works like previously. New look visually. Strange that we are all experiencing different bugs.
Proximity Sensor problem again during phone call with jelly bean update. Ugh! Is anyone else experiencing the well documented proximity sensor issue since update? Everything was fine with last update. This issue is quite annoying.
Thanks
Yes! Me too! Happened with the first call I tried to make and all consecutive after. This happened with my first EVO 4G LTE, so I got a replacement. I'm thinking this is hardware related? What do you think?
Thanks
This. It is very annoying. Is there any work around?
I'm not sure it's hardware because with the previous update I personally had no problem with my current phone. The phone I have now is my second evo 4g lte. The first one I bought on release date and I did exchange that because of proximity sensor problem.
kctraci1
