Build.prop help
Mike Moreno3
Ok so earlier today I edited my build.prop file so the android version says 5.1.1 instead of 5.0.1. Turns out when I saved it my root went away with it. So basically my phone is tricked by thinking I am running 5.1.1. I did save a backup of the stock build.prop file but my problem is I can't restore it without root. Is there any way I can move my backup back to /system/?
Well, if I were you, I'm gonna make myself a flashable package thats gonna replace it. Flash it to replace and set permissions and done, reboot. Just search in Google for how to make it.
Posted via the Android Central App from my Samsung Galaxy S4 I9500
fisthack07
