Build quality difference between black and white, or sloppy launch devices?
angry english
555
My old launch white Nexus 5 had a really loose power button and volume rocker, you could literally move them around in the cut outs. The new black one I have does not have this issue, everything is tight, no rattles no nothing.
I know manufacturing techniques become easier after a while but I'm quite surprised.
Or is it a case of the black Nexus 5 was always this way and it was just an issue with the white one?
Not putting the phone down at all, was just something I noticed the very instant I first turned on this black N5
How certain are you about that? From the article, the difference in grille size doesn't seem that pronounced. Are you able to compare your N5 with others?
I have a white one from launch and no loose buttons or other flaws.
Sent from my LG-LG870 using Tapatalk 2
Well they did fix the buttons but i dont think they fixed the speaker holes. I just got the red nexus 5 and i still think it has the small speaker holes.
I just got my red nexus 5, volume seems OK but the power is a bit loose in there (not so bad that I'd return it). Also I did notice smaller speaker holes.
One small thing that I didn't like was that they used the same old nexus 4 charging cable which you'd have to turn upside down to plug in.
I think the issues are more pronounced on some devices. It's definitely there.
Well actually i think i read that an LG representative denied the new hardware revision on the nexus 5. She said they hadn't changed anything on the nexus 5.
They have definitely have changed something as like I said in the 1sr post my newer black N5 had none of the issues that my white one did regarding build quality
uOttawaGrad_22
