Building your own ROM
Did you pick your lunch menu first?
Code:
. build/envsetup.sh
lunch "whatever the package you wish to build (for VM670 "8")
make -j(number of CPU Treads) bacon
The thing is that toro is not on the list on the menu. So I lunch full_toro-userdebug and the make -j4 otapackage and I still getting the same error. I am gonna try the patch below
tapatalked? from cowsquadGnex?
MOAR NUB Q's!
OK, so installing the environment as the 3rd post: the package lib32readline5-dev doesn't seem to exist. I find lib32readline6-dev, but other searches return nothing. Helpz?
did you
Code:
. build/envsetup.sh
/edit/
sorry, my phone browser went all psychotic and was replying to an old post.
duh.... been a poor week for brain function.
javadoc: error while loading shared libraries: libjli.so: cannot open shared object file: No such file or directory
make: *** [out/target/common/docs/doc-comment-check-timestamp] Error 45
make: *** Waiting for unfinished jobs....
make: *** [out/target/common/docs/api-stubs-timestamp] Error 45
i did run make -j4 and the compiler took like 3 hours to finish. Now, i am getting those errors above
I did run make
MOAR NUB Q's!
Distro and version?
I did run make
You need to post more than this.
Sent from my One V using Android Central Forums
Those are the only errors I am getting. On top of that there is nothing
Wee need to know where its erroring at. Just post more output than what you did.
this is the entire error
Docs droiddoc: out/target/common/docs/doc-comment-check
Docs droiddoc: out/target/common/docs/api-stubs
target SharedLib: libutils (out/target/product/generic/obj/SHARED_LIBRARIES/libutils_intermediates/LINKED/libutils.so)
target SharedLib: libhardware_legacy (out/target/product/generic/obj/SHARED_LIBRARIES/libhardware_legacy_intermediates/LINKED/libhardware_legacy.so)
target Symbolic: libdvm (out/target/product/generic/symbols/system/lib/libdvm.so)
Install: out/host/linux-x86/lib/libdvm.so
Install: out/host/linux-x86/lib/libSR_Core.so
I am building Aosp.
Really? Anyways, now that I look at it closer, hardware/libhardware_legacy doesn't seem like its throwing the errors. But, I'm done helping, seeing as you like to argue about everything and I don't feel like dealing with it right now.
Huh? Arguing? When? Okay, don't worry man. I'll fix it on my own. Don't worry
Are you on you period lol jk . Cool, :-)
Neither of these posts are helpful at all, let's try and keep things civil. You've both been reported.
Cow squad, are your sources up on github?
OK. I was going to take a look. Libjli.so is having problems
So libjli is part of java SDK 6 and it is located in its respective folder. I already created a alternative for javadoc as well, but that doesn't help. When I run make -j4 otapackage , I don't get that error. Weird
Fletch1998
