Calculator error in Android 6.0.1, how can I fix it?
  • Start date Start date
Re: Calculator error in Android 6.0.1
10% is .1 therfore 100+0.1=100.1 How is that wrong? You are not wrong either! If you try many calculators you will find differing results. 10% onits own doesnt mean anything so i guess some assume its x% of 1 whereas others assume its the other value in the sum.
You my friend are a stickler. I have the same problem on my Note 5. It's not a concern whether the calculator is right or not due to a decimal point, the problem is if I'm trying to take 58% out of 1000 I can do the math in my head no problem but if it's an odd number we need our calculator to go ahead and do that for us. For everybody that has this problem I downloaded another calculator that works great it's called calculator Plus and it reminds me of an old Texas instrument calculator for high school
I'm having a problem on the built in calculator app on my Android phone where it kinda looks like some sort of overflow error. For instance 12/33 gives 36363636363636. But 12/12000000 gives the proper result. It looks more like some setting was accidentally changed but I don't see any settings. I've tried clearing my cache, but that didn't make any difference. I'm running Android 6.0.
pratikkumarBB
