Call Interface - how to get rid of it
CarolynA2
10
Samsung Galaxy S8 / android 8.0 / Samsung Experience 9.0 / Sprint. I think it has been since the last software update that I get this ridiculous cartoon notification after a call. Can't figure out how to get rid of it - or whether it is a Sprint, Samsung, or Oreo thing. Help would be appreciated.
Thanks
Looks like neither (definitely NOT an Oreo thing, and it doesn't have the style of Samsung apps). It looks like a 3rd party app. Have you tried looking in your apps for something called 'Screen Flash'? Did you install anything else recently?
I remember seeing a similar issue on another thread. If I recall correctly the culprit was some backup and restore app. Next time you get this popup open your recent apps and see which is the last card listed there.
thanks. haven't pinned it down yet. ruled out one backup/restore app. And Javier P., it didn't seem to leave a card. will keep testing recent apps.
It is a new feature of an existing 3rd party app on the phone. One way to quickly find the culprit, is to tap okay, just to see which app it wants to add, then close without installing. . Note the developer, and it will probably be one of the apps on the phone made by them .
Thanks
I have the same issue, if you find out how to get rid of it can you post i here?
Thanks.
ruhidubey017
