Call volume
At this point, I'd contact Google support through the system settings (Settings>Tips & Support>Contact Us) and see if they can help. Sorry!
You could always do a factory reset as well, but I know that can be a hassle.
I've never had a good result from contact with Google Support. All sessions have ended with a recommendation that I do a FACTORY Reset and if you remember, I won't factory reset. I'll see what they recommend.
Thanks for your help.
Sent from my Pixel 6 using AC Forums mobile app
Suddenly, the volume of phone calls have lowered to levels that make understanding phone calls difficult. I didn't make any changes. It seems to be associated with the Assistant.
The volume otherwise is OK. I've tried the command in Assistant but it tells me that the volume is at maximum.
What could I be missing? Thanks.
I'm noticing that too.
I'm fine when I'm on pixel buds.
Sent from my Pixel 6 Pro using AC Forums mobile app
fikasta2
