Camera and Camcorder won't work after 2.2
Is your camera and camcorder working post 2.2?
  • Total voters
sed51329
384
21
I click on the icons and the screen goes black for a second, then goes back to the home screen. Anyone else getting this?
Edit: problem solved. uninstall the led widget
I am having the exact same problem. I have tried to launch it every way possible and also rebooted. Nada. Sup with this?? Say it ain't so!
Is call Spring, but they'll make me do another (my third) hard reset. And I really don't want to so that.
Working perfect here. Did you try doing a reboot, not reset, of your EVO 4G?
Sent on my EVO 4G with Tapatalk
I uninstalled Vignette and now both work perfectly. Must be incompatible. Maybe a reinstall of Vignette will work, but I'll try that when I'm done working with all the other stuff.
I never had Vignette installed. So that can't explain mine not working
sigh...
If you have LED light installed from the market uninstall it.
Also can try turning on/off the flashlight app included in 2.2 and then try your camera.
I also uninstalled several other things I no longer needed. Uninstalled the LED Light application, HTC_IME keyboard Mod, Dolphin HD Browser, and a couple of other things. After I finished with my uninstalls, the camera worked perfectly.
Maybe it's one of those uninstalls that got things working? There might be another app or two I took off, but that's all I'm remembering now.
Had the same problem with the camera app not working. So, uninstalled LED Light, and now everything is working fine. Wish I could change my vote. I voted no before reading through the thread.
Reinstalled Vignette, and all is fine. That wasn't the offending app. It was the LED Light app.
sigh...
BINGO!!! That solved the problem!
:( I loved that app- it was simple/fast and had a cool widget that matched the other HTC widgets. Maybe it will be updated...
Thanks again
I had this problem in the past and uninstalled Fring and it worked again. Try that if you are using Fring.
66lottery
