Can I create a second favorite applications panel?
The "Edge Navigation Pro" app has had a major update.
It's existing 2 panels can now act as 2 additional app launcher panels (limited to 4 apps per panel, total 8 apps).
Or it can control system actions such as camera, volume, recents, etc.
Or it can control device settings such as WiFi, Bluetooth, GPS, brightness, etc.
I say "or" because there are a total of 8 positions that can be assigned on the 2 panels (4 per panel). So you could assign 8 apps, or 4 apps and 4 actions, or 2 apps and 6 actions, etc.
link (2nd on the list)
Is there a tutorial on how to use this Pro panel app. I cannot figure the thing out.
You can download a panel called edgeboard faves. It's similar but it includes recent programs. I use it though
Is Edgeboard listed by default or does it need to be sideloaded in Note Edge?
EdgeBoard is not in Google Play, it is only in Samsung's "Galaxy Apps" (which is where the phone's "Manage panels" setting directs you to). So sideloading not needed.
However, Galaxy Apps takes a while to update versions and is still showing v0.5.
The developer has released a newer version (v0.6) that includes:
-fixed landscape not working for all 3 panels
-added options to hide tasks or favs from the main panel to give more room to another list
-increased spacing between items somewhat
-fixed running task list being empty on the main panel
v0.6 is available HERE. (needs to be sideloaded)
Re: Second Favorite Applications Panel
On my AT+T Edge, the "second" Favorite Panel appears to be locked (no pencil/edit button at the bottom of it in Manage Panels).
It has the Favorite "star" at the top, but tapping it does not open it for editing (like my first Favorite Panel).
It currently has the following icons:
  • Milk (edited... thought it was a Music icon:)
  • Gallery
  • Drive?
  • SoftCard
  • Folder (with a bunch of AT&T apps in it)
  • GooglePlayStore
  • Calender
Can your second Favorites Panel be customized in your Verizon Edge?
This has been FIXED in the Lollipop Update !!! This panel now has the pencil/edit button and is fully editable !
Wow, great call out. I was hoping they would fix that.
redmercer
