Can I get some help with an Android 5.0.2 Wifi problem?
Mike Pawka
14
I had been running the TWC Android app on my Samsung tablet on Android 4.4.2 for several months without any problems. Recently I "upgraded" the tablet to Android 5.0.2. Now the App quits running after a few minutes and wifi communication is lost, a wifi scan doesn't even find the router. After a system restart wifi starts working again.
Re: Android 5.0.2 Wifi problem
Sorry to hear that you have issues with WiFi.
What router/access point are you using and would it be possible for you to test if this also happens with other networks?
Do you see any difference in performance if you restart the phone or turn off bluetooth?
Mohamed_1rashad
