Can I get some help with Smart Remote on my Galaxy S5?
RaggTagg
11
Help With Smart Remote on Galaxy S5
Does anyone know how to set up a sound bar? I tried doing so under AV Receiver, but it didn't connect with my Philips sound bar. Tried all the buttons, but is there no place to manually enter a code?
I have reset the app, both within the app and in Settings/Application Manager where I deleted cache/data/force stopped.
I contacted support (Peel) but got a canned reply which suggested the reset above.
Any tips? Thanks.
witnessloc12
