Can I view what is draining my battery?
A
AC Question
I know how to view running apps, so that's not the screen I want. My phone is dying really fast recently and I want to see whats putting a drain on it-only 2 apps running and I don't believe they should be heavy drainers. I saw this topic here:
http://forums.androidcentral.com/samsung-galaxy-s4/368357-why-my-samsung-galaxy-s4-all-sudden-draining-so-quickly.html
Wondering where he saw this screen, though I don't believe that's showing how much each item is draining the battery, I think it's just showing running time for each-correct me if I'm wrong on that. I have a galaxy s4 like him.
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,421
284
83
Hello,
By me it is, how you say..
Instellingen - meer - batterij -batterijverbruik
Institutions - more- battery - battery usage
Greetings..
Welcome. :)
Yes, 'Settings' is the word used in English, rather than 'Institutions', although I like the latter. :)
Ja, 'Settings' is het woord dat gebruikt wordt in het Engels, in plaats van 'Institutions', hoewel ik hou van de laatste. :) [Google Translate.]
Rukbat
Retired Moderator
Feb 12, 2012
44,529
28
Settings/Battery. Look at what's draining the battery. (You don't need a 3rd party app.) If the mobile data line at the button of the next screen (tap the graph to get to it) isn't solid green or off (like yellow or brown) you have a weak mobile signal, which costs battery, and you should be on a different carrierm, one that has a better signal where you are.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,737
4,905
113
Welcome to Android Central! Do you also have an S4? Different phones can have somewhat different battery menus.
In general, to help us figure out what's draining your battery, do the following. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
If you can't find some of this information, it might help to install a good battery monitor like GSam Battery Monitor.
http://forums.androidcentral.com/am...ide-how-post-screenshots-android-central.html
Tim1954
Q&A Team
Jan 17, 2016
6,924
Your battery could be on the way out. Or if you're on a weak network signal area, that will consume a lot of battery. Do as suggested above to find what's using it...
NotifyWord
