Can you disable the screenshot sound?
Open the app "enforced stream silencer" and check the box; uncheck the box if you want the click sound back.
Like the others said, theres no way to turn the shutter sound off. I have the Razr Maxx and I dont know why they didnt make it possible to turn it off. They def messed up with this one. I'm going to try to contact motorola and/or android to see if something can be done about this.
Enforced stream silencer doesn't work for me (screenshot sound) galaxy s3. V4.1.1. Thanks for suggestion tho
I read this on a forum and it works for me.
-Select CAMERA
-Select SETTINGS
-Scroll to the bottom and deselect SHUTTER TONE.
.So I have read this forum and I don't think anyone has suggested this, if so I apologize. Anyway, I have an HTC inspire and this is the only phone I have tested this on. I figured out how to make the shutter sound for screenshots as loud or quiet as I like. This is what I did. I have my notification volume set to the same volume as my ringtone first of all. Also I have downloaded from play store an app called Android Assistant. In Android Assistant you click tools on the top right then click on the volume control section. In there you can adjust whatever volumes you want. I believe the shutter sound is linked to the notification volume so I can just put my phone on vibrate and it did work as well. Remember to set your notification volume to be the same as the ringtone volume in settings. I have tested this so I hope it helps everyone.
Thanks,
Jeremy
Edit: I forgot to mention that if you have the notification volume set to the same as ringtone volume then you should be able to use the softkeys on the side of your phone to set to silent or vibrate and that should do just as well. Sorry for the confusion.
installed the enforced stream silencer on my non-rooted droid 4 and it works like a charm...no more annoying shutter sound:)
disregard this post lol i forgot to hit the button to remove read only...duhh
Great post, this helped me get rid of this pesky sound ;)
I have tried to use ES File mgr/explorer, but I keep getting "unable to rename file" message.
-Jay
Galaxy Tab 2 10.1
liquidsnake757
