Cannot stream live on Sumsung s3
Hi I want to thank you. But I must say if you did not give me .http://173.192.70.132:8054/stream/1/ I would have no way of finding that so for other sites it would not help. I did try to use Xiialive and search for it but it could not find it until I entered the above. It seems there should be a easier way. So now I am stuck with flash. If you have a way for me to search and find were I can use it that would be helpful.
Thank you
The way I got it was easy. I use Winamp here at work. I clicked on the link on the website and it opened up the stream on my Winamp. Just look at the link on winamp and put it in Xiialive and you're good to go. If you have further questions, PM if you like.
motoJunkie1
