Sal Anthony
- May 10, 2014
- 6
- 0
- 0
Wow, I've same problem. I'm almost certain it has something to do with our wifi connection -- too weak, or not constant. I never used wifi calling, because, I always ended up w/the problem we're experiencing. I've looked for the feature to disconnect it, but haven't located it as of yet. I don't believe a replacement is the solution. My wifi wasn't constant, so I disconnected it during calls, problem solved. If anyone finds a way of disconnecting wifi calling on the s5, a response would be greatly appreciated. TY!
