can't load android system - is there way to fix it?
  • Start date Start date
A
Android Central Question
I'm getting this error and nothing seems to work. Is there a way to fix it without factory reset??
Which phone?
Can you get into the phone ?
I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
https://forums.androidcentral.com/showthread.php?t=409154
It's Lenovo Tab 4 8. All I can see is loading screen then error message "can't load android system" and options try again or factory reset.
Launched Android recovery options too, tried rebooting and wipe cache. Doesn't work. Factory reset is rather last thing I wanna do, so trying finding other solutions.
Hi, if you welcome to AC!
At this point your going to have to try factory reset if you can't get into the phone.
Is there way to recover photos after factory reset? Like some program, application or something? I haven't back up unfortunately.
If you didn't have them backing up to Google photos or drive I don't think you going get them back , there are some programs out there that supposedly work but as long as I've been in the forums haven't heard much success in that .
Welcome to Android Central! Did you happen to save the photos on the SD card rather than Internal Storage?
Ishimwe
