Can't take screenshot uses volume/power button
camelot023
15
I have the Sprint G4 and I can't get the volume down power button combination to take a screenshot. Did sprint disable this option? I can use the quickmemo+ but I'm curious as to why the other button combination doesn't work.
Any ideas...
Disregard, apparently I just needed to get the feel for it. Press both buttons simultaneously and hold for a half second or so.
It's a little awkward, yeah, but pressing & holding those two buttons will do the trick.
Makes me really miss my old S4's "side-of-the-palm swipe" to take screenshots.... *sniff*
-Phil
I have a hard time pressing both buttons. I usually get the darn volume and have to fiddle with it everytime. So I usually just end up doing a quick memo.
Sent from my VS986 using Tapatalk
I guess I'm lucky in this regard. I always get the screenshot function to work this way. Although this was how I did screenshots on the nexus 5, too, so I have a lot of practice.
I just had an issue with my note 4, where I couldn't take any screenshots, even while holding the home and power buttons simultaneously. My solution was clearing the cache, once I did this, everything worked perfectly!
Been doing it since the G2 no problem just takes getting used to. Takes two hands on most other phones.
Posted with LG G4 via the Android Central App
Lifesaver. I was wondering what was the reason it didn't work, turns out just clear out the cache and you're good to go. Thank you so much
liquidsnake757
