car mounts
I can vouch for the Proclip line. I have been using them for several years now. They are on the spendy side but worth the money. I am using the specific car mount for my vehicles and then a Universal holder for my device. I use to get a device holder for each specific device but the universals work just as good and save money in the long run. They are pretty high quality and never has any issues with breakage or anything else.
Found this today on clearance at walmart for $5.
It says for tablet, but works great on my lg v20. I disconnected 1 of the 2 springs inside because it was very tight.
Got this one. just not sure where and if i'll put in my car. the only reason i can think of needing a car mount is for gps. i have onstar, and also a tomtom on my windshield. and any text or calls show up on the screen of my car. but it is a cute little mount.
http://a.co/fLasj8L
http://a.co/fLasj8L
Just got a used 2010 traverse. I was hoping it had Bluetooth since it had onstar, but no such luck.
I disabled onstar... Can't see paying for something that Seems so primitive and something that Bluetooth does for free... But again, I don't have Bluetooth. :(
So odd to have onstar but no bluetooth.
Hopefully it has a 3.5mm jack cpuld used a Bluetooth adapter.
It does have a 3.5 jack. How does a Bluetooth adapter work and what inexpensive but decent one would you recommend? Thanks
carts21
