Cases and screen protectors?
hey, do you find yourself using the card holder? i dont' know how much i'd use it, it's not quick draw, know what i mean?
also, does the hook come undone easily? like accidentally?
Its exclusively for swipe card use. I use it for my bus card which works on a system where you hold the card within a couple of centimetres from a receiver and the case works great for that. I'm assuming it was designed for credit cards which use this technology and for this it would be great as its heavily concealed for extra security since theres no pin.
I doubt the hook would come undone accidently, maybe after a long time as the hook wears a little but thats inevitable with anything really. To open it you have to push outwards from the screen against the joint which is a pretty weird angle to catch your phone on something with but I guess its possible
Reactions: Funkpod
I think I'm going to go with a Vaja case. Yes, extremely expensive, but well worth it.
Vaja Leather Products
Wow, these are truly beautiful... but I'd be concerned b/c they don't appear to adequately cover the edges at top & bottom. Looking at prod photos there's one where the phone is tilted forward and you can easily see that the phone edge is exposed and will contact surfaces -- not much protection in a drop. *sigh* still lookin'
williestringfield90
