Cases for the Nexus 6P
How easy is it to remove? I have a Spigen case like this now and I can get it off pretty easily. I had one prior from another company and it was VERY hard to remove. I thought I was going to break my phone.
I haven't received it yet but it should behave similar to the IMAK Cowboy cases, i.e. will be rest to remove.
Edit: I received mine yesterday and have been using it since then. Impressions so far is good. The material is sandstone finish and feels better in hand and provides adequate grip for one handed usage.
Hi, I was wondering if your still using this case & How you like(d) it? Also if you use a screen protector w/ it, is there one you recommend? Preferably oleophobic
I don't have the 6P anymore. I actually am using a 5X as a loaner from a friend while I wait for the Pixel. The 5X has the case. It isn't bad.
I wanted to buy this case but I read that it doesn't offer a lot of protection. How do you feel regarding that aspect? & are you still using it? Thanks for any feedback
I keep my phone protected all the time. I've been using this case along with a tempered glass protector and it has survived some drops without getting a single scratch. The drops were not on hard concrete but in my house. The case does provide good grip so one handed use is pretty easy.
Very much appreciate the advice. I'm going to go w/ this case & the Spigen rugged case. Love your profile pic!
One last question if you don't mind. How well does the case protect the front of your 6p & like edge protection also? In case it were to fall on the front screen or edges along the screen?
It definitely does not provide any front protection, the lip size is pretty narrow. It does protect the edges though. I use a tempered glass protector with the case and it has survived a few drops so far.
Thank you, that was very helpful. I'm about to buy a couple cases now & am narrowing it down.
Just got the Centra Snap case today.. Love love love it, love the look, feel & everything. Def. agree that I wish it had more front protection, but it's almost perfect. Love how you get glimpses of the beautiful Gold 6p underneath due to the design of the case. Very happy, appreciate you're help! Thank you
That's a slick case. Does it keep the screen off the table top when you place it flat down?
I've used the same type of case on all my phones. Cruzerlite TPU. It gives you a good grip, and protects around the edges. Also the cutouts are real. You touch the actual buttons, not a piece of something that is covering the buttons. Cruzerlite makes cases for every phone that i can think of....except the iPhone, and that works for me.:p
I'm looking for a slim you black case anyone have suggestions? Also don't want it to be a glossy black like I see most look like on amazon?
I have been digging the Supcase Unicorn Beetle Series PremiumSlim Hybrid Protective Case / Bumper from Amazon -
on/off and volume controls are tight!!
williestringfield90
