[CDMA HERO ROM] Gumbo ROM 1.5c
Oh well. I suppose I'll just find another calendar widget. I really like the HTC bar callendar widget, but it's ok. I only use 3 homescreens, so bare should be fine for me. Nice job :)
Smooth calendar widget FTW. Its in the market or inside the addon package. looks sense-like but shows more than one entry.
Flashing Bare now. That's awesome that you included one without SenseUI.
EDIT: Here are some screen shots of the amazing (can't say that enough!) Gumbo1.5c.
As you can see, I've customized it a little more to my liking. But, for those who wondered if Expresso would work, I can confirm that it does. So do the 2.1 Icons and Clear screen!
This has to be your best ROM yet, absolutely incredible work! Extremely smooth and extremely fast.
I was testing 1.5c before official release and found out it was a bit slower than the other ROMs (including Gumbo 1.5b) when running the Gumbo kernel. Is the final 1.5c release displaying this as well or was this fixed to mach more 1.5b speeds on menu transitions/app menu scrolling/etc?
I've seen greater speeds with 1.5c actually. I have Bare + SenseUI and my phone is extremely fast. My memory stays at solid 80-90 and everything just feels so much smoother. The transitions and scrolling are both very fluid as well, even with the on screen keyboard. I don't know, YMMV. I'm extremely satisfied though!
Did you use the test 1.5c before testing this final one? For the record, I love Gumbo?s work, I have tested it before just want to know if there are differences on the hood of this final version before committing.
No I didn't test -- I wanted to, but I couldn't find the download and by the time I did find it, 1.5c came out. 've ran 1.5b for a month or so before switching and for me personally, 1.5c seems a lot smoother. I like the fact that the kernal is built right in and that the CPU is set to On Demand. My battery life is excellent, my apps load up quickly, everything seems work extremely well.
Ill definitely test it then. So if you don?t use Powersave and stick with OnDemand all the time, then SetCPU is not needed?
Yea, pretty much. I haven't installed SetCPU -- and I don't plan installing it, I see no reason to change whats already been perfected!:D Good luck with the switch -- I hope you get good results!
Aweosme ROM GB!! Im running the BARE ROM with the Nexus Launcher from XDA that emerica. So far its FAST!! I knew 1.5c Beta was fast after trying it the last couple of weeks, but DAMN, you out did yourself once again! Good work my friend!
Is the kernel on 1.5c different to the latest stand alone Gumbo kernel in terms of speed/memory management?
Hey gb, are we able to install HTC's widgets on the bare ROM? For instance, the bookmarks widget or the calendar widget...
I'd suggest including Sprint Nav in the Bare ROM, or having it as a separate update.zip not included in the rest of the Sprint add-ons. I got it installed, but it would be very useful to simply flash.
Voice Search Stopped Working
The rom seems to cause a problem with voice search. The app is still there, but voice search always force closes. Any help or fixes would be greatly appreciated.
Here are some screens of what mine looks like!
Looks good! I like the launcher. However, I can't live without some of the HTC widgets, so I went with Bare + SenseUI (Pictures in the beginning of the thread). Either way, this ROM is absolutely amazing and its a win win for everyone!
I never really used any of the widgets except for the calendar and bookmarks one. I can live without it. LOL I think this ROM is great as it was a couple weeks ago when he released the beta.
i just upgraded from b to c and i dont know if its something i did but i went with bare and installed the addons pack and the fancy input animations in spare parts doesnt work..fancy rotation does but thats it..any ideas?, great rom btw :)
tryhomematch
