[CDMA HERO ROM] Gumbo ROM 1.5c
Hey gb, thanks for the help on the taskbar. I changed the color and touched up the icons to make them transparent. Everything looks good. I just need to find the HTC sync icon to make it transparent.
not sure but the thought of setting up this rom scares me lol ... wish the cube was gone
Just remove the Cube...
* Delete Cube files.
/system/app/CubeLauncher.apk
/system/lib/libcascades-3.5.4.so
/system/lib/libcascades_jni-3.5.4.so
/system/lib/cascades_plugins-3.5.4/libhoudini.so
and delete the /system/lib/cascades_plugins-3.5.4 folder
reboot
Nice. When you have it done please post the files. You know someone else will want it.
Use Bare + Sense. No cube that way.
couldnt i just remove the cube apk from the package before install ?
You'll want to remove the libraries as well, and you need to resign the zip if you go that way.
I'm having a hard time finding the stupid sync icon for when you plug it in. If its the one I think, than its not gonna work. You know where I can find it? I'm gonna try and sign it so it can be flashed.
Ha! Well someone answered :)
Haha yea I saw that, but for some reason its not making the change. I grabbed them and made them transparent. I pushed them back to my phone, but it didnt change. I did however change the Messages icon a different color other than green.
Ok, so here is what im working on...If anyone shows interest i'll zip it, sign it and make it flashable.
Looks really good! I'd go ahead and zip it up and share it. Be sure to make a new thread with it so it gets the attention it deserves and people can see it
Thanks! I'll probably seek your help to get it zipped. LOL I havent grasped that part of it yet. I need to change the bottom Rosie bar and clean up the Messages icon. I noticed its showing a little fuzz...lol
hey does 1.5c bare have a music player? i put that on and now I dont see music or media anywhere?? and actually reading and the bare doesnt have a music player? is their an apk or something I can get to add it without adding the senseui addon?
and I was also wondering if its possible to get stock contact list and not the sense version?
There is no vanilla music player for 1.5 on CDMA devices. Your choices would be to build it from the AOSP tree, download a third party app from the market, or push the HTC music player to the phone. The framework is still in place so the HTC one will work fine if you want to push it back in.
Contacts, calendar and dialer are the same way. Vanilla won't work, so we have to use HTC or download/build an alternative.
Ok guys, maybe someone can help with this. I've been running 1.5b w/ kernal. Went to flash 1.5c, everything force closes. Can't even get signal, no bars whatsoever. I obviously am doing something wrong since it's working for every one else. So I flash back to 1.5b and everything works. Any suggestions or maybe even a tutorial for us newbies. Thanks.
arcworldwide
