Charging Indicator[Solved]
Jetskier222
17
My phone used to display a charging indicator for a few seconds when I plugged it in, but it has stopped. Anyone know of a setting to get it back.?
Re: Charging Indicator
Make sure your usb port clean , if so go settings>apps>3 dots upper right corner tap system apps and find usb settings and clear its data and force stop it
If those don't work , you probably going have to factory reset , this is done by system UI , safe mode it didn't work that means no 3rd party apps were conflicting.
I messed with these settings didn't Matter it still showedScreenshot_20201226-213352_Settings.jpeg
Found it! B. Diddy's link gave me the answer! Remove animations was toggled on, as soon as I toggled it off it came back. Thanks for the help guys!
This.
srabon
