- Jun 20, 2012
- 46
- 0
- 0
Hello
I have a new problem. I used to be able to charge my phone using the USB port on my computer and the USB cable that came with the phone. Recently though the battery will drain even though it's charging via he USB port any idea why? I tried rebooting the phone incase any application were running is the background causing a drain, but that didn't help.
Another issue is sometime when I try charging the phone using a wall charger the screen will go crazy. For the some reason the phone will detect key presses even though the phone is lying on the table by it's self. For that I use a usb adapater to connect to the wall. It's a 5v 1A output.
Lastly at times I have to fiddle around with the microport to get the phone to charge or the computer to recognize it. I guess the charging port might be defective. Is that something that needs to be fixed quickly or will waiting cause bigger problems down the road?
