Charging stops at 99%, after 3 seconds carries on charging?
  • Start date Start date
A
AC Question
Hi guys, got my S8+ 2 days ago. Phone works fine but when I charge it I've noticed/heard the notification, of when you plug in the charger, go off. When I've checked the Phone, when its happened, it's at 99% and then proceeds to 100%.... its happened every single time ive charged the phkne. Just wondering if anyone has encountered the same issue?
But it's still at 99% when I hear the notification... my Note 4 and S7 edge never did that, reached 100% and the light went green... on my S8 + it's still red when the notification sounds...
But you said in your OP that it then turns to 100%. I would assume there's a small lag between what triggers the notification and what controls the LED.
Sorry I should have worded it differently, I meant to say that when this happens, it eventually charges up to 100% but takes a further 5-10mins to do so
heritagevine05
