ClockworkMod Recovery/ROM Manager Guide
What steps did you get stuck on with the procedure in this thread, and the alternative procedure I gave you?
And btw you are rooted, correct?
i am rooted i go and do the flash of the kernal my phone restarts i download clockwork app fash the recovery reboot into recovery and i get the stock recovery instead of clockwork and the alternative way i downloaded the update put it in the root of my sd card flashed back to the recovery slected the update.zip and it fails
Since you are having a hard time with both methods, I would suggest waiting until the 26th when official Froyo is released. There will probably be a flashable version of official Froyo with Clockwork pre-installed - I will post it in this forum so check back.
one click installer and Clockworkmod Recovery v2.5.1.0 made by noobnl, skeeters
lint, and koush
Press any key to continue . . .
remove stock recovery patcher
adb server is out of date. killing...
* daemon started successfully *
mount: Operation not permitted
rm failed for /system/etc/install-recovery.sh, No such file or directory
rm failed for /system/recovery-from-boot.p, No such file or directory
copy kernel and flasher
1192 KB/s (313888 bytes in 0.257s)
1678 KB/s (5820868 bytes in 3.387s)
flashing kernel
RedBend Update Agent 6,1,14,1
FOTA : Make Block Device Nodes
lcd_init(498): start!
lcd_init(507): fb0 open success
lcd_init(514): width = 480, height = 800
open device file: Permission denied
bmldevice_get_size: bmldevice_open failed!src: /sdcard/zImage
dst: /dev/block/bml8 partition size: 0x0
part_size: 0x0
reboot: Operation not permitted
wait 60 second
cleanup
rm failed for /data/local/tmp/rageagainstthecage-arm5.bin, No such file or direc
tory
rm failed for /data/local/root.sh, No such file or directory
done
this is what i get with rutryfirst
this is what i get with runtrylast
lint, and koush
flashing kernel
part_size: 0x0
wait 60 second
cleanup
tory
done
I need help i have samsung galaxy s2 and its rooted running insecure kernal its got
Android sytem recovery <3e>
and when i use rom manager and click flash clockwork recovery i keep getting
E:failed to verify whole-file signature
E:singature verification failed is there anything to stop this happening
also its running android 2.3.5
also m root method was odin and s2 root there the tools i used
This isn't the correct forum. This is for the original Galaxy, not the Galaxy S2, so I'm not sure if anyone here will be able to help you with your phone.
SUBJECT:Your Sept 14th 2010 Android SDK software downloasd link
I have a LG Virgin mobile Optimus V Google based Model #VM670 Android cell phone.
The ADB tools to root my cell phone were not in the SDK software I downloaded a few months ago to root my above android phone.
Is it legal & FREE to redownload the SDK software package where ADB tools are included to root my cell phone to free up available phone space since certain apps I downloaded cannot currently go to my 16GB SD card. Please let me know ASAP! Thanks!
Yes the Android SDK package is free to all to use. The tools you need are simple enough to get after you download the SDK package and start it.
Once it brings up the list of downloadable packages "updates/add ons" for the SDK you need to select the option for "Platform Tools" which is near the top of the list. That will give you ADB, fastboot and other apps that are needed to root & manage devices.
Android_4life
