Cold As Ice working on Optimus V!
+1 for Clocksync, it's great. Not perfect, but makes things MUCH better.
What settings are you using for ClockSync? I've tried 30 second auto sync and every other option I could figure out and it hasn't seemed to make a difference.
Sent from my VM670 using Android Central Forums
Auto-sync enabled, 30 minute intervals, high precision mode, sync on boot. If you're running AOSP, it might not work, last time I tried root access was broken, which Clocksync needs for automatic updating.
Reactions: Nonnef
Root access works fine on AOKP
Sent from my LG-E739 using Tapatalk 2
Since the OP seems outdated I'm gonna ask. What do I need to download and install to make this fully functional on my OV??
i thought cam was fixed with the latest build. I could be wrong. Ill be flashing the latest CAI ROM later on tonight. Ill report back if any issues with that.
Everything is working on 10g and if you want to watch video you record download mx player
sent from my device using XPB ICS Tapatalk 2
I have it set to 1-day intervals, automatic synchronization, and only when awake. I have had no issues since installing.
The clock-lag was almost a deal-breaker for me on all of the ics roms. This was an awesome find! Thanks again, rebel69ization!
Reactions: rebel69ization
Ugh! Mine doesn't Dx
U guys have Any idea why it doesn't ?
Check md5, wipe cache and dalvik flash again. If MD 5 matches and you wiped caches and it still doesn't work, try wiping everything and do a clean install, if that still doesn't work, do a logcat at the time its trying to connect, and pastbin it here
I know it does. That's why I said AOSP ;) Irrelevant anyway since this is the Cold As Ice thread, lol. My bad.
Oops I kinda missed that one my bad lol I'm seeing things o__o
I am getting a status 7. what do i do to get the rom to install. i wiped it and cleaned it and still wont work.
Abheetha Athukorala
