Cold As Ice working on Optimus V!
Alpha10g is a pleasant surprise, very nice. Love the videocam, no issues since flashing at 6am
Sent from my LS670 using Xparent ICS Blue Tapatalk 2
I can confirm it works on 10G
Is this the original fix posted here or is there a new one that needs to be used? The one I have is no longer available for download so I'm wondering if I need a new one because of that...well that and the name...
Code:
cm9.a6.homekeyfix-1.zip
That's the one I have. The a6 part is what makes me nervous. I would think that would refer to an alpha version 6 unless someone can point me to something that says otherwise. Meanwhile I'm downloading the rest of the updated file now...
--bornagainpenguin
Code:
--bornagainpenguin
Here's the newest one, it's working for me with 10G:
cm9.a10.vmfix1.zip
From here, : http://forums.androidcentral.com/lg...70-5-6-zvd-basesband-alpha10.html#post1612822
Code:
--bornagainpenguin
Yeah that one is outdated, you should check the cold as ice thread more often for updates. Everything is there in the OP and yes use the fix that was posted, it should work.
Reactions: bornagainpenguin
Thanks guys. I swear I must've looked right it and still missed it. :eek:
--bornagainpenguin
Anyone else having issues with Link2SD? Or is this supposed to automatically bind any apks like TDM's version? Because it's just not happening for me.
This ICS ROM is really just amazing. i fell in love with ICS all over again.
I cannot believe the progress this ROM has been through. Mostly all experimental. Its not like you can just copy code and hope someone fixed it.. WOW. Haven't tried the latest update though...Ill try it and see if i can replicate that issue. Keep up the good ROM work!
using cold as ice cm9 10g standard flash with gapps nd vm patch on zvd9 radio rom is hauling ass working wifi nd camera checking video. THANKS KRAVEN!!!!!!!!!!
I'm thinking of switching back to IHO, only because I just got an LG myTouch 4G and it has a CM9 nightly build with all the latest stuff, and everything seems damn near perfect on here.
Sent from my LG-E739 using Tapatalk 2
I was under the impression that this rom contained the theme Chooser... :confused:
Sent from my LS670 using Tapatalk 2
Welladjusted
