Cold As Ice working on Optimus V!
@Another, I thought it was Eri.xml?
Haha another...:p
It might be that too, I just wasn't thinking and spit out what it is for gingerbread and froyo. I still suggest changing that in the build prop too though.
Everything is working great, but your right about one thing. The mms. Seems like it sends, but it really doesn't. Everything else but that and the camera preview works amazing
What about the other way around? I care about getting them more than sending them. I can send pics any number of ways but I cannot force other people to do the same.
Same here. Just tested it now. I sent the picture from another phone and it won't work. You get the notification, but you can't download the picture. :-\
Have you try, checking the apns-comf.XML that its says something like
apn-virgin mobile us
mnc 490 mcc 311..........
Its under system/etc/apns-comf.XML
its pre applied i talked to thekraven the dev of cold as ice he said swap the framework.res.apk
it does not look pixelated at all, compared to tmd's.
google music fc's when streaming though.
i know it says LS670 as far S/W wise my phone is concerned its a optimus S but i didnt have to flash a radio so i can go back to OV roms anytime i want
Sent from my LS670 using Tapatalk 2 Beta-5
Anyone else having Market problems? I can't download a thing... error 921 if that helps.
No problems for me, flashed this last night and downloaded a few, just checked again prior to this response and no issues.
The camera has no preview just like tdms, no big deal to me. Its still better, smoother, clearer, etc. If you can't live without mms install go SMS pro or wait for a dev to make a fix for it. This is still a lot further along than tdms in my opinion
sent from my ice cold OV 4.0.4
Curious noob, you're right you did say that flashing any cm7 or 9 would work thas why I did it! THANK YOU.
i tried to install via recovery yesterday and got an error about thunderc and it aborted on me. im using cwm 5 green recovery. didn't make it far enough to flash kernel or button fix
Heartworms
