Common issues and solutions
I appreciate the effort to help but both of those are nothing but a placebo effect at best and do NOT fix the problem at all.
Can I highly recommend that you post that comment within those threads? That way they're more likely to lead to a solution.
my notification light flickers white, even though no notifications, any ideas please
I've never seen this problem... have you tried posting a separate thread in the G4 forum? Do you have any special notification apps running? I used to have "light flow" (I think it was called) and there were some bizarre light actions happening. Anyways, you should post this question as it's own thread.
When adding contacts to LG G4 and someone has more than one mobile, how can I identify a Personal Mobile versus a Work Mobile? With my former Samsung Note, I could define my own Phone types. With this LG G4, i can't figure out if I'm able to configure my own.** If I'm not, i'm feeling lost as I have several people with multiple cell phones and I keep getting them mixed up.
You can make a new one with his/her mobile and call it mobile 2 or work cell. As soon as you add a number in the phone slot, you'll have the option to put another one in and so
Hi I have an important issue on my lg g4.. Now i m on marshamallow 20b with root, in order to install m.v20d I deleted my previous nandroid backup(3gb of memory) and i wanted to do another backup but my memory is "full" .. Thought I deleted the backup(3gb) my free memory is 1.5 gb. How is damn possible?!
You should probably start a new thread on the lgg4 forum... you're more likely to get people viewing it.
I resolved the problem by using the "junk files deletion" of the Android app "es file Explorer".. The nandroid backup file was in the cache .. I don t really know why this has just happened
I have a no-so important issue on my "Marshmallowed" G4. It happens when I have my knock code put on and Smart Lock activated (my usual combination).
When Smart Lock recognizes my face and unlocks my G4 (then I need to swipe) the swipe animation.now SHOWS THE INTERIOR BLACK as shown below:
I don't find the solution >.<
I've never used the Smart Lock recognition, so I wouldn't know... but you might want to post this as a new thread in the G4 forum, as you're more likely to get noticed :)
Thank you sswitzer! I did create a thread but actually I can say you are the first to pay me attention about this. That's why I thank you so much :)
You're welcome :) I think the thing is that most people don't use the Smart Lock recognition feature, so they're probably all scratching their heads instead of helping ;)
- Steve
My LG G4 constantly disconnects from WiFi. I have tried to forget the network and add it again but I still get the pop up telling me there's an authentication issue. The password is absolutely the correct one and other devices do not have this problem.
Lelix2603
