compatible flash player for nexus 10 with jellybean 4.2.2
I don't know about the sleeping, but I'm thinking that running it from ac will cut down on the battery usage?
As stated above, Flash does not work with Chrome or the newest version of Dolphin (I reinstalled an older version of Dolphin just to use Flash). I do not have a problem using the flash player with Firefox though.
Don't understand why Dolphin would disable Flash capability....
Hi using the above post I went to the link he posted for old versions of flash, he mentioned that if there was a bigger number at the end of the version he used 11.1.115.32 to go for it. I found they now have on the top of the list 11.1.115.81. I followed the rest of his solution. It worked perfectly. I did not have to do anything further. I have the latest jellybean. 4.3 on a Nexus 10, and was using Firefox to watch a live stream of a WWE ppv. Shush, don't tell anybody that part. :-)
Ok, got ff and installed flashplayer 11. 1. 115.81 per above now how to get to ff settings to enable plugin? I feel silly havig to ask this. Galaxy note 8.0.
If you just want to watch youtube videos, type m.youtube.com in your browser. This switches from desktop viewing to mobile, and the flash prob is solved.
Nzone888
