Compatible SD cards for Nokia 6 and their usage?
experimancer
18
Which SD cards are the best and compatible with Nokia 6?
How big can the card be?
Can the Android 8 be configured to store all pictures and videos and all the user data to SD card only? How about the Android apps data, cache and configuration, can they too be kept in SD card, if yes how?
it is Micro SDXC compatible.
This means it should be fully compatible with any micro SD card currently available. That means the current max size is 400GB. It should also be compatible with new microSD cards as they become available. In theory they will eventually be available in 2TB.
qatestings
