Connection failed- Note 4 & Gear 2 Neo
Re: Connection failed- Note 4 & Gear 2 Neo
I downloaded Gear Manager Assistant and it fixed everything... Sucks I had to pay 4.99 for it but in the end was worth it just install and hit download will automatically download all apk files needed for gear
Thank you. Where is the correct location the file should be stored?
I copied it to my SD card and then double clicked on it to install.
Re: Connection failed- note 4& gear 2 neo
I just got the gear 2 neo and have a Note 4 running 5.1.1. S voice is not connecting and I can't locate tell someone voice apk mentioned previously in the post. Any ideas about what can fix this? I tried clearing the cache and sat in the s voice app. In the gear app on my phone, I can't even open the settings button for the s voice app. Please help!
Download an install the svoiceprovider.apk that I posted in a previous post.
I see the post where you said you posted the file but it is unavailable for me to click on to download.
heres the svoiceprovider.apk. Now my svoice works.
Hi do you still have the apk, I have the same issue. It used to work on my old note 4 but have just had it replaced and it does not work on this phone.
GUYS I FOUND THE SOLUTION
I was about to factory reset my Gear 2, so i backed it up via app. I wanted to see what the app backed up so I restored it, and it backed up everything, BUT I opened S voice, and viola! So just backup and restore your Gear (no reset required). Hope this helps (for anyone still out there)
oval_clarity
