Contacts Transfer
Yes, it possible to transfer contacts through Bluetooth from Nokia to Nexus4.
You have to mark all contacts, select "send business card" and send Bluetooth mode to transfer it. its very well worked for me.
In nexus select the contacts and import it.
--Nithin
@OP: Try the app called Listables. This allows you to export all the contacts in the desired format (VCard, CSV, html etc.). It allows the user to simply send that file as an email (or) upload to dropbox etc.
on your Lumia, you can simply import the file and everything should be restored easily!
I am not aware of any direct sync applications though.
hope this helps!
hope this helps!
No, I need the contacts on my Lumia to be imported to my Nexus 4.
might be too late - LOL- but you can install the outlook app and sync contacts...that's all :)
Hi I tried Wondershare Trans, however Nokia Lumia 920 is not listed under the supported cell phones. Can u tell me how to change from hotmail contacts to google contacts.
alexsonburgus
